メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
Poor signal after screen replacement
A friend has taken a phone to have the screen replaced.
After the repair the phone has very poor signal. I've done a soft reset/ hard reset. I then checked and the antenna is correctly attached and the bars in the right place.
I know on older models the short is something to motherboard. Can this affect the 5 too.
Anyone found any fixes?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
Did you all disconnect the battery terminal when you done this repair?
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Richard how can it be for a different model?
さんによる
Some of the models of 5 and 5s even 5c have different screens i have noticed some are a little bit thicker and it can cause a huge draw on the battery I heard of this problem before and they claimed it was because the screen that was replaced was thinner than the one they received. Because of the different companies that make the screen
さんによる
But you couldn't even connect a 5c or 5s screen to a iPhone 5 cause the connector is the opposite way around
さんによる
Maybe the different companies that make them I am unsure of the validity of the info I had received but it made perfect sense if a company cheaply makes a iPhone 5 screen it could take more power thus increasing the heat and lowing the signal because it doesn't have the power to operate at full strength. That is why I asked for feedback to see if their is truth to their claim. My personal experience with them I haven't had this issue but I have heard a lot about it.
さんによる
Makes sense I wonder did these boys disconnect the battery if so they could have knocked off componants around it..
さんによる
1以上のコメントを表示
コメントを追加
Same issue as mine!! Looking foward to find a solution! :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I'm having the exact same problem. Just replaced my screen, and now I have very little signal and the phone's battery drains really fast and the phone gets hot. All I did was replace the screen, and this isn't the first screen I've replaced. It didn't do this before on the other phone on which I replaced the screen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Check connections it may be heating up because of a poor connection also double check the screen if possible if its for a different model iPod it will have a huge draw for the power making the signal weak. Let me know if this helps please.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,631
