メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Black screen after replacement
I just replaced cell signal antenna and the power-button/sensor cord and I adjusted the home button, cause it was too tight.
After I was done and put it all together, the screen was white on one half of the screen and black on the other half, after 10 seconds the white faded away and it all got black.
I then turned it off by holding home and power button, then I whiped the LCD and digitizer connectors with a piece of paper, I also replugged the battery connector just to be sure.
When I reassembled it again, the screen wouldn't even turn on at all. To make sure it actually was on, I Connected it to the PC, it turned out to be on, but the phone speaker itself made an beep noise every 5 seconds while Connected to the PC.
What has happened?
Update:
I cleaned the connectors again with Windex on a Q-Tip.
Now it's just back to black screen, but atleast it's on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
You may have damaged the LCD cable of your screen. did you try another screen?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Can I try another screen without the replacement procedure, just attach the cables?
さんによる
コメントを追加
回答を追加する
Mats さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 470
