メインコンテンツにスキップ
Predecessor to the Compact Fluorescent Light. Invention is credited to Thomas Edison in 1879.
2回答 すべてを表示
I can't change the lightbulb by myself!
I have a bulb out in one of my lamps. Can someone come over and change it, please. Please be sure the wattage is consistent with what the lamp can handle. I prefer soft white and am a GE fan, but any manufacturer will do. Also, I don't really like the energy saving flourescent as they cast a ghastly green shadow on my otherwise ghostly complexion.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 15
10 件のコメント
How many (Aggies, Poles, etc.) does it take to install a light bulb? How high is this lamp? Can we get to it with a fork lift or do we need a fireman type ladder? Who's paying for all this?
さんによる
I guess we are happy Gabe didn't call 9_ _ .
さんによる
Maybe someone will do a teardown this so we'll all know how.
さんによる
This is a real hard one. I suggest we'll fly in a quick response team of experts ;-)
さんによる
I can definitely change that, for a fee. Plus travel expenses, and 10% of all merchandising, perpetuity, and ancillary rights... aaaaanyway...
さんによる
5件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
Well, as iFixit doesn't really offer services, I'll try to walk you through this in as clear a manner as I can.
First of all, it's helpful to do this in the day time- then you can see what you're doing.
  1. Turn off the light
  2. Wait a minute for the bulb to cool down
  3. Look at the number that is on the top of the bulb- it's probably something like 40W or 60W
  4. Make sure you have the proper replacement- I would suggest not going above a 60W bulb
  5. Gently unscrew the dead bulb. Make sure you work in a straight pattern, so as you can get the bulb out with minimal hassle
  6. DON'T TOUCH THE INSIDE OF THE SOCKET!!!
  7. Get your replacement bulb and carefully screw it into the socket. You'll know you've screwed it in far enough when it is firm, but not unmovable.
  8. Flip the switch. If you worked carefully, you should have a working light again.
Enjoy!
このアンサーは役に立ちましたか?
スコア 21
3 件のコメント:
By the way, this was all in jest.
さんによる
don't you think we should check to see if the bulb is really out first? Maybe it's not screwed in far enough. or maybe it got unplugged, or maybe the switch is broken, the wall plug could be out or the electricity could be off. Maybe the OP just has a loose screw ;-) + vote for the thought
さんによる
By the way, if anyone wants to know whether this question really was a joke, check out the profile of the asker.
さんによる
コメントを追加
Get a girl friend, you obviously spend to much time on the web.
このアンサーは役に立ちましたか?
スコア 11
8 件のコメント:
Humor is good around here, and while I'll admit this question is a little comical, that's just uncalled for. -1
さんによる
another down vote from you rab? and why me?
さんによる
Because I don't think it's funny that you're ridiculing someone who needs help, it's very insular and gives a bad rep to this site, not very encouraging or particularly helpful. This 'answer' also should be a comment, so that's that. but I'll leave it at that, I'm not getting into an argument.
さんによる
another two downvotes today a year after the question was asked, and anonymous to boot. There really are some cowardly scum bags around here. At least rab had the balls to say why. Put up or shut up.
さんによる
+ Gabe more than likely needs a girl friend. If he's lucky he'll find one that knows how to screw in a light bulb.
さんによる
3件以上のコメントを表示
コメントを追加
Check if the lamp is still under warranty. If so call the support line and they'll give you a RMA number to ship back the lamp and you'll get a new one. If you're lucky they can even ship you the newer model.
このアンサーは役に立ちましたか?
スコア 9
コメントを追加
i touched the inside of the socket.... it hurt.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Did you light up?
さんによる
コメントを追加
At about the age of nine, I stuck my thumb in a light socket just to see what would happen. Therefore, from personal experience. I can solemnly attest and confirm that Brock is telling the truth.
IT B****Y HURTs !!!
(And here in the U.K. we have 250 Volts.)
(Well actually only about 242 by the time it gets to the little village where I live now.)
Did this experience really change my life ? I became an electrician, and have had a good few belters since then.
Please take our word for it, ...
DON'T TRY THIS AT HOME !
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Don't forget..when removing the old bulb and replacing the new.....righty tighty/lefty loosey.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If you are have trouble extracting the old bulb, here's a proven safe method:
You will need: crate of beer, firm hands (at first).
1- Unplug lamp,
2- Hold on to bulb,
3- Drink beer until room spins, et voilà! Easy out!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Gabe さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 11
過去 30 日: 35
今までの合計 8,916
