メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
Where can I find these blue capacitors on the U17_RF?
While trying to replace the screen I pried off a blue (what I assume is) capacitor on the U17_RF. I have no idea what this is and where I can find this. The blue capacitors look like all the other blue ones located nearby it.
Does anyone know what these chips are? Any help please? Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
yingwang01 , as you already know that the part itself is U17_rf and it is used in the antenna line as a duplexer for GPS antenna and cellular diversity (top antenna). The blue caps are part of that assembly, SASLE1G58AA0F57, and do not show separately. Since it is a duplexer, those should be filter caps. I would try to bridge the gap where the cap used to be.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Wow Oldturkey! They should give you an award for all the input you contribute! :)
So if i bridge the gap it wont damage or screw up the phone operation in any way?
さんによる
Looks like those are filter caps, so you should be okay with just bridging that particular component ;-)
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 683
