dryer makes thumping sound
When ever we dry clothing, it sounds like there is a shoe in the dryer. Makes a. Thump, thump. Quiet. Then thump thump in that pattern until the load is dry. Any ideas?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
There are several other things it might be, so let us know if this is not it.
このアンサーは役に立ちましたか?
Here's what Chumbawamba says to play while doing this repair: https://www.youtube.com/watch?v=2H5uWRjF...
could be one or more of the fins in the dryer drum is loose.
このアンサーは役に立ちましたか?
where is he fins your talking about
Me too. Only happens for a short time at start of drying cycle.
このアンサーは役に立ちましたか?
Susan did you figure out what the problem was? I am having the same issue
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 10,510
