メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
締切られた回答
Battery replacement is done except something is not working.
I have recently fixed my iPhone 4S months ago (around since March 2013) from water damage. I didn't turn it on but instead I just cleaned it up first and tested it with my friend's battery and it works. I didn't have money that time to buy a new battery so I laid it aside until I bought one.
After I have bought the battery and installed it, I had it charged but here's the odd thing:
- When I plugged the iPhone to a charger... I do not see a battery charging icon but instead an Apple logo on startup but turns off after a second or two.
- Without the battery, I tried plugging in the charger... The apple logo shows the same way.
- I tested the battery I bought on my friend's iPhone 4S... It works. Battery has no problem.
- I tested my friend's battery on my iPhone this time, it doesn't show signs of life.
This didn't happen before because I was able to have a charge icon from my friend's battery.
Did I miss something?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Good chance that the phone corroded while it was in storage. Remaining water, although not a problem at the moment given time will raise the humidity inside the phone. Which can cause damage over time.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
So, even if I cleaned it with a solution (which of course evaporates the water)... It happens that the chemical likely corroded the components inside the phone?
さんによる
Maybe, giving these devices time to lay around usually isn't good. It might be worth taking the phone down and closely inspecting the board to see if it shows corrosion.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 103
