メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
20回答 すべてを表示
iPhone 4 stuck on apple logo then turns off
The phone gets stuck on the Apple Logo for 20 secs then turns it self off. I have tried restoring, updated it, etc. When restoring it shows the progress bar but as soon as its done it just goes back to same issue. I have also entered my phone into DFU mode and doing a complete restore with no luck. Your help will be appreciated. Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 77
19 件のコメント
That is similar to what i have wrong with my IPhone 5s. It stays off but once i try to turn it on in all ways it goes to the apple logo screen for 10-20 seconds then turns off. I cant update it, restore it or do anything. It only goes to the apple screen and off. Is there a way to fix it? Or possibly get my pictures off of it. I have important pictures i can't loose.
さんによる
i have the exact same problem! have u fixed it yet?, can u tell me what to do
さんによる
Hey Hanah Doellens how did you go i have same problems as youre 5s aswell please help
さんによる
we have all the same problem but you must restore your iphone just put your iphone in DFU mode then restore it using itunes 11.3.1 hope this will work for you!
さんによる
If it fails, maybe you can try to fix iPhone 4 suck on Apple logo by using recovery tool.
さんによる
14件以上のコメントを表示
コメントを追加
10件の回答
ベストアンサー
It is more than likely that you need a new battery :-)
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
It came after I tried to update it to newest IOS update...to use the app store...but those &&^&@*@ Apple as I suspected would turn my 4s into a brick those bastards.
さんによる
コメントを追加
最も参考になった回答
Hi there, try these steps:
Connect the iPhone's USB cable to your computer, but not your iPhone.
Turn your iPhone off. If the phone won't turn off in the traditional manner, just keep holding the buttons until the screen goes dark.
Once you've turned the device off, press the home button on the face of the device and plug in the USB cable to the device's dock connector.
When it turns on, keep pressing the home button until the iTunes logo appears on the screen.
You'll know the phone is now in recovery mode because a window in iTunes will tell you.
You can then start the restore process by clicking the "Restore" button in the iTunes window.
Hope this fixes the issue.
このアンサーは役に立ちましたか?
スコア 18
19 件のコメント:
it did not work for me it just got stuck on the connect to itunes scene
さんによる
hi i have the same problem + home button is broken,what should i do?
さんによる
I had the same problem with my iPhone 4. I have tried all options which is available in apple supports communities but that didn't worked. After sometime one of my friend told me that it could be hardware (booting chips or another chips) issue. He suggested me to contact local iPhone repairing center instead iphone authorized service centre b'coz they charge more than local repairing centers. I did exactly as suggested and gave it to the local rep. Centre. Next day They told me the same(chip damage ). They replaced the chip and charged me 2000 Indian rupees now my phone is working well. I would like to inform all of you they charged me more than double amount. So try and negotiate with repairing centre. regards RAKEYSH RAWAT (RR). rawatrakesh59@yahoo.com
さんによる
my iPhone 4 does this too. thinking maybe the battery died or can no longer hold power?
さんによる
Thank you! Can't beleive it. After 2 weeks of not getting past the apple sign I thought the internet was a slim chance .. but its working!
さんによる
14件以上のコメントを表示
コメントを追加
Try a new battery
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
this was exactly was solved my problem! :-)
さんによる
コメントを追加
i went to the apple store and they said mine was water damaged. to know if it is or not, look in the headphone jack and shine a light down it and see if the bottom is red. do the same to the charger jack. if they are red, water is in your phone, if it is no color, there is no water damage. but since they said mt phone had some damage i decided to still try this. and i worked so even if they tell you you have it, still try everything until you are possitive it wont turn bck on. :)
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
so what if it is red in the head phone jack? what then, can you put it in rice to dry it out and it work again?
さんによる
it did not work because it will turn on and then off repeatly
can u help me with this problem email me at :keegan.parrish072@sccdsb.net
さんによる
コメントを追加
Hi, I have encountered the same problem. Finally I successfully solve it with FonePaw iPhone Data Recovery.
Try this first:
In most cases, you can solve these problems by putting the phone into recovery mode and restoring it from backup. To do that, follow these instructions:
1. Connect the iPhone's USB cable to your computer, but not your iPhone.
2. Turn your iPhone off. If the phone won't turn off in the traditional manner, just keep holding the buttons until the screen goes dark.
3. Once you've turned the device off, press the home button on the face of the device and plug in the USB cable to the device's dock connector.
4. When it turns on, keep pressing the home button until the iTunes logo appears on the screen.
5. You'll know the phone is now in recovery mode because a window in iTunes will tell you.
6. You can then start the restore process by clicking the "Restore" button in the iTunes window.
Hope it can help you.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
plug the iPhone charger in to your laptop/computer then press the lock button for 10 seconds then press the home button for 15 seconds
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the same problem so I called apple and changing the charger fixed it!:)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Maybe this will be helpful:
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Iphones check to see if there are any non apple components after an upgrade. Non OEM batteries are the target. If you have replaced your battery the phone will work fine until you do a software upgrade. When you do the upgrade, shortly after your phone will detect a non OEM battery and shut down completely. You will get one of two responses. A completely dead screen or, when the charger is plugged in, apple logo and nothing else. You can get Itunes to recognise the phone but it will refuse to do a restore.
Replace the battery with an OEM battery and the phone will be back to noemal. Don't we love Apple!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
B I just fixed my friend's iphone 4. I have tried 10 times but there was no chance to be successfully restore. Finaly, what am i doing is get a plastic bag, put your iphone into it, and put the plastic bag in the freezer. Make sure there is no water in the plastic bag. After that, just watch your tv, play your game or do anything else for about 1 hour. After that, don't waste your time, don't wait till it's hot, don't wait anything just restore it, and may God bless your iphone. It worked for me, and my friend just speechless because he nearly wanted to waste a lot of money to service his iphone. Good luck with that, hopefully this may be useful. My suggestion, don't use iphone :). Thank you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Musa さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 29
過去 30 日: 86
今までの合計 149,052
