メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
iPhone 5 screen is loose
My screen protrudes too much from the rear case assembly because the rubber/plastic (?) material which originally lined it on the left side has separated, and as such it is free to move around in that area.
I am wondering which options exist for replacing or repairing this issue, preferably without buying a whole new display assembly. Do I just need to apply adhesive to the side of the glass? Better yet, can I buy a new glass and swap it for the one of the assembly I have right now?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
If it is not affecting your phone other than moving around a bit, I would just leave it. Replacing just the glass is near to impossible since it is heated onto the LCD. You could try buying a case that secures the phone together, that way you wont be letting dust and dirt in there.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I would recommend to either get a case that would not allow it to move. Like Dustin said you cannot just buy the glass and replace it that way. It requires very expensive equipment to do that. I would also look up your serial on Apple's website and see if it's under warranty. If it is, then schedule a Genuis Bar appointment at the nearest Apple store to see if they would swap out the part or phone for you.
https://selfsolve.apple.com/agreementWar...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If the phone is within a year you can take it back to apple for an exchange. I'm sure they will give you a refurb but its better than what you are doing now.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Marcus McLean さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 22,824
