How to open g4 a1104 case
How to open case after removing all screws how to seperate top from bottom with out breaking, any ideas other than just sticking a card into it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here's the guide on how to tear it down, just carefully follow it: PowerBook G4 Aluminum 12" 1-1.5 GHz Logic Board Replacement
このアンサーは役に立ちましたか?
follow the guide +
If you're certain that you removed all the screws take something like a creditcard or a similar stiff piece of plastic an carefully lever it in the gap between top and bottom case. Be espacially careful around the optical drive slot.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 3,075
