メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
[NAND] Find flash media and keepout
I recently installed a new ifixit screen on my girlfriends iPhone5, and it worked fine, but the speaker did not work due to the spot on the camera where the speaker "grounds" to being ripped. So I had an old, fried, iPhone 5 laying around, and decided to use its good condition camera. Install went smooth, no issues at all. Went to turn on the phone, and boom, NAND error. I researched and researched and researched, tried several methods. I can't get the phone to go into DFU mode, but I can get it in recovery. I tried restoring it from recovery mode, but it gives me ERR: 4013. Researched it, updated iTunes, updated my Mac, made sure firewalls are off. Still ERR: 4013. I tried leaving the camera unplugged, and at one point it did not give me the NAND error, but it did not boot passed the apple logo. I put all the old stuff in, and still no avail. Any help would be greatly appreciated!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
6件の回答
ベストアンサー
try booting up without the flex cable (front camera) plugged in. if it works, buy a new flex cable.
have a nice repair
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
AND IF that doesnt work check the board for shorts and avcorse THE U2 CHIP WHICH IS AVCORSE DIFFERENT ON THE IPHONE 5S ! THIS IS A KERNEL PANIC
さんによる
コメントを追加
I encountered the same issue, I have fixed countless iPhone 5's up until this point. Kudos to iWillFix, this solution worked for us
I noticed this error occurs when the device is turned off intentionally or the battery drains, once the device attempts to reboot the Error occurs. so with that being said, make sure you turn it on and off with the camera flex disconnected, and when you replace it with the new one, i would sleep better by testing it about 5 times to make sure it still boots with no errors.
A few tips for testing this method, disconnect the camera flex with the device on while its showing the NAND error, do a hard reset by pressing the top button and using a metal spudger to make contact where the home button flex makes contact with the charger port. (I do this often on other iDevices *works like a charm and saves precious time)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
THIS IS THE CORRECT ANSWER !------->>>>> IT DOES NOT SUMS UP IN THIS !!
this issue is happening and can happend from the U2 chip ! which is causing kernel panic ! also the back lcd bezzel is shorting the lower connector make sure it is not shorting everything !!! KERNEL PANIC CAN BE CAUSED FROM SEVERAL REASONS AND NOT ONLY THE CAMERA ASSMBLY AND DISPLAY !!!!
HOPE THIS WILL HELP YOU! the u2 CHIP CAN ALSO CAUSE THIS
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
NAND errors are typically due to a flex problem.--with the case described here, it is almost certainly the camera flex.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Had this problem happen to me a couple days ago. Turned out to be the front camera/proximity sensor flex cable. Ordered a new one and installed it and this fixed the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Where is the U2 chip? And I am getting the same running scrip down the screen with only a fresh screen plugged in, no camera.
I did change a bunch of caps that a customer knocked off in self-repair attempt. Got them all on and getting this error. Don't think the chips had polarity. Double checked. No polarity on the ones I changed. Checked continuity and everything checked out.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
show us your board
さんによる
コメントを追加
回答を追加する
Dustin Monroe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 10,525
