wHAT IS pin out/timing on AT050TN34V.1 lcd 67pins
The AT050TN34V.1 is the 5" lcd in a garmin.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
jeffrey, not sure where you get the "67" pins from. This is the data I have from the panels datasheet :"
1 VLED- P Power for LED backlight cathode
2 VLED+ P Power for LED backlight anode
3 GND P Power ground
4 VDD P Power voltage
5 R0 I Red data (LSB)
6 R1 I Red data
7 R2 I Red data
8 R3 I Red data
9 R4 I Red data
10 R5 I Red data
11 R6 I Red data
12 R7 I Red data (MSB)
13 G0 I Green data (LSB)
14 G1 I Green data
15 G2 I Green data
16 G3 I Green data
17 G4 I Green data
18 G5 I Green data
19 G6 I Green data
20 G7 I Green data (MSB)
21 B0 I Blue data (LSB)
22 B1 I Blue data
23 B2 I Blue data
24 B3 I Blue data
25 B4 I Blue data
26 B5 I Blue data
27 B6 I Blue data
28 B7 I Blue data (MSB)
29 GND P Power ground
30 CLK I Pixel clock
31 DISP I Display on/off
32 NC - No Connection
33 NC - No Connection
34 DE I Data Enable
35 NC - No Connection
36 GND P Power ground
37 X1 I/O Right electrode – differential analog
38 Y1 I/O Bottom electrode – differential analog
39 X2 I/O Left electrode – differential analog
40 Y2 I/O Top electrode – differential analog
I: input,O: output, P: Power
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 174
2 件のコメント
How to change those pin become HDMI ?
Any idea ?
Thank you.
Heri さんによる
Heri, I am confused by your question. what are you trying to accomplish?
oldturkey03 さんによる
