メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
BlackBerry Curve 8520は、洗練されたデザインと優れたパフォーマンスを実現したエントリーレベルのスマートフォンです。
x on the signal bar with any sim card
with original sim card or any other sim card there is an x on the signal bar, so i am presuming that the signal receiver is broken. i have opened up the backberry and im looking at the chasis or the motherboard. Where is the signal receiver and what does it look like?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Couple of things:
First, I read your previous question and I'm not convinced it is an antenna fault. However, to answer your question the antenna looks like this and costs about $2.00.
Second, I believe, if it is a hardware issue, that it may be the SIM card reader itself. If that is the case you may need a new logic board.
Third, the little "x" in the signal area usually means that it is still actively searching for a signal, but is not in range of one. So it is possible that since you were changing settings for unlocking the phone that it is searching for a signal that is is out of range of. If this is the case it means your hardware is all perfectly fine and you have a software (settings) issue.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
hello i have cell phone blackberry curve 8520 icant type keyboard thank you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kayleigh さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 19
今までの合計 809
