メインコンテンツにスキップ
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418回答 すべてを表示
New Airport Card - still no/bad reception
I was having a similar issue with my Airport reception as others so I replaced the card today and there is no change. The works/is fitted correctly as it can see close by networks however it will only give 1 bar reception and will not connect to them unless you are say ontop of the router.
I thought it might be the antennae but I don't know if this is replaceable or if its even the antennae that's the issue. Any help would be great.
Thanks
Scott
MacBook Core duo 2ghz
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Try carefully cleaning (no power attached) the slot and ends of the card. A pencil eraser on the ends of the card is abrasive enough to clean off oil or corrosion... plugging and unplugging the card a half-dozen times should clean the connector. Examine that the connector is not breaking loose or has solder joint cracking
The antenna wraps around the display (study the guide) It can be replaced... but that is a major DIY project. Check that the antenna is not damaged where it passes through the clutches (hinges)
You could try an external antenna on the router or, on your laptop.
There are many variables that affect wireless reception... For example, if you have a new router and an old laptop the router may not broadcast on 802.11a/b/g by default OR if it's an older router & a new laptop it may not broadcast on 802.11g/n at all.
The threshold and beacon interval of the router may need to be adjusted.
If there are other routers, or wireless devices you may have to try changing channels.
If there's heavy traffic on the router signal may diminish
If you live in an old building the wiring of the building, microwave ovens, motors, hand held cordless phones could provide interference.
The composition of the floors, walls, plumbing/heating in the walls could provide interference.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Machead, Have given the connectors a clean and it seems a lot better now.
Scott
さんによる
コメントを追加
回答を追加する
Scott さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 85
