メインコンテンツにスキップ
モデル番号A1137/1、2、4GB容量/カラーオプションはブラックとホワイト
68回答 すべてを表示
Battery Change Didn't Cure My Problem
1. I changed the battery and the Nano seemed to work fine for a day ot two. Now the same condition reappeared of no battery charge. It only plays when powered by external device like Docking Station or when plugged into the computer.
Any suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
sounds like the new battery is empty or there is something wrong with the power circuit - something drains the battery - was there a fluid damage or something like that ?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hello,
Thank you for taking the time to respond. I was also thinking that maybe that something could be wrong with the power circuit resposnible for recharging. Ifixit is sending me a replacement battery. This one will tell the story but I dread reopening that Ippod. No no battery leakage.
さんによる
opening the first gen. isn't that bad - newer ones are horrible ;-)
dorry - i didn't mean a battery leakage - i ment water or any other "non technical" fluid
sometimes the slightest fluid damages could make problems - check and maybe clean the dock connector with a paintbrush and rubbing alcohol.
i've seen this many times on cell phones - a little damage (or dirt) on a dock contact could be able to make charging problems
さんによる
コメントを追加
回答を追加する
tomasnie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 640
