メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
締切られた回答
Glue on the LCD connector
Hiya guys, I need help, tried doing a replacement screen on a customers LCD/digitiser but I accidentally got glue on the LCD connector, therefore the new screen doesn't "click into place" properly, anyone give me any ideas to fix this? Kind regards Matthew
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Ooh that stinks. I would use either of these methods:
If there is a lot in there.
Hot glue becomes brittle when it gets extremely cold.
Place the iPod in the freezer and allow the glue to get very cold and brittle.
Remove it and work quickly with a small paperclip, or metal poker (careful to not damage the connectors) to break up the glue and scrape it away. Often the glue will pop off of the surface when it is so cold.
Or, if there is just a little bit in there, I would recommend using acetone.
Acetone is a well-known adhesive remover and works well for removing thin layers of hot glue.
Moisten a cotton ball with acetone or acetone nail polish remover and apply it to the glue.
Blot with a clean cloth. The acetone will break down the glue so it can be transferred to the clean cloth.
Continue applying the acetone and blotting to remove until the glue is completely gone.
I wish you good luck sir in your endevors, hopefully everything works out.
Ash
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 154
