Graphics chip repair with heat
Hi, I was wondering how can I repair iBook's g3 famous graphic issue. So, does putting logic board in to oven for awhile will do the job? I was thinking about 300 celsius.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
watrobkasmaczna, the idea about a reflow is that it reheats the solder. The theory is that fractures form inside the solder points on boards, which causes instability. By reflowing the solder, you could get rid of the fractures, and sometimes you can bring apparently dead parts back to life. But, there is a bit more to it than just throwing it in an oven :-) Check on here on here for more information about reflowing. This idea or even this one might be a better way of doing it, unless you have a reflow station. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 177
