Left Earpod Has No Bass and Sounds different from the right
What has happened? the Earpod is quieter, and distorts the audio. It was hanging from my shirt, and then i put it in my ear and then this happened.
Look down in your connector slot with a flashlight to see if a small piece of debris is causing a bad connection. Blow it out or rub it with rubbing alcohol gently to clean the plug in while holding it upside down so the alcohol runs back out if any try's to run
このアンサーは役に立ちましたか?
What is a connector slot and where is it?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 9,553
