blue veritical line on Vostro 1015 lcd screeen
blue veritical line on lcd screeen
The vertical strips are dead pixels. That being said a cable could be torn messed up inside your device and so on. Is this a tv a computer or what?
このアンサーは役に立ちましたか?
anusha, a single vertical line is usually caused by a TAB eror. Check your signal cables to make sure it is properly seated. If it is, the LCD needs to be replaced to get rid of that line. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 319
