メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Laptop released by Dell in 2005, features a 15.4" display and Intel Centrino processor.
Why am I getting a blank screen after dell logo start up?
I turn on laptop, and see the DELL logo and then nothing but a blank screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 16
10 件のコメント
Jackie, try this first :"1. At start up press F2 and enter the BIOS Setup, does the BIOS see the hard drive is present?
2. If you remove/disconnect the hard drive data cable (or disable the drive in the BIOS setup), does your Dell computer say,
"strike F1 to retry boot, F2 for setup utility"
If the drive is detected properly, but you get only a blinking cursor, yet removing/disconnecting gives you the message in #2 it is a boot loader problem.
3. Run Diagnostics (they are built in) - When you turn on your comptuer if you press CTRL + ALT + D (Not Delete) it will say something like:
IDE Drive Diagnostics running, please wait..."
さんによる
Thank you it is working. I have diasabled each and every device and found that CD/DVD drive is not working so the loader keeps on checking for Drive problem( for 20 mins) once it could not figure out it switches to other device. If you disable the corresponding device it works fine
さんによる
No matter what I do the Dell logo just comes on and the screen goes black.
さんによる
Hi
My leptop is give black screen on start-up
Battry is not working
Please resolve the problem all the function are working n running properly but screen getting black
さんによる
Guys I have a problem where my dell laptops starts up and shows all the login stuff but when i get in, there is nothing. Help here please. Nothing shows up even after all the logo and the login, even afterwards it doesn't. Need help here
さんによる
5件以上のコメントを表示
コメントを追加
6件の回答
最も参考になった回答
On those old Dell laptops you can "reset" them by unplugging it, removing the battery, then the RAM, replace the RAM then the battery. This can clear all kinds of minor glitches. However, if the problem is of a more serious nature then you may have to contemplate cutting your losses and getting a new laptop as this one is worth less than it would cost to have it repaired professionally.
I wouldn't work on this laptop if one of my customers brought it to me other than checking for simple way to fix it. I'd encourage them to let me salvage date off of the hard drive in order to move it to a new laptop.
Good luck.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
what about if you are in a place/country where replacements are not easy options:-) any chance there is a fix to it? could this be caused by a bad hard drive or no OS?
さんによる
No, this wouldn't be caused by a bad hard drive or no OS. Each of those would cause it not to boot into windows, but there would be an error generated by the BIOS in both cases. From his description it's not even getting to the BIOS. The number of reasons for that is to many to count.
If he is "in a place/country where replacements are not easy options" then he's screwed. I give it about a 90% chance he'll need to replace something in order to fix it. In that case he'll need two things.
1. The know how to trouble shoot the hardware himself.
2. The ability to get parts for an 8 year old laptop in a "place/country where replacements are not easy options".
If he dosen't have the knowhow to fix it himself then he'll be paying someone else to do it and it'll end up costing at least as much as a new (cheep) laptop, if not a lot more.
さんによる
Okay, so mine goes like I turn it on go log in then I go to Google Chrome and it goes black I believe it turned off, but It's on the charger so it's not the battery. I need to fix it ASAP because it's my grandma's computer! :/
さんによる
コメントを追加
just follow these steps this might help you - try restarting your computer in safe mode
and after that try restore in safe mode and cut down not wanted software from start up and i also check for viruses and for more visit dell http://www.dell.com/support/home/and after all steps restart the computer lets see if that works for you . gud luck
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
this can be a step to step fix - first try booting laptop into safe mode restart the laptop and than press f8 and fand select safe mode with networking . remove some unwanted programs and cut down few unused start up programs . than update the windows . for any other step visit FIX laptop screen black computer startup see if this fix the issue . thanks
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You can try performing a system restore before you try to install a new OS so for perform system restore is to open safe mode by clicking F8 on start-up and check safe mode
option then further a dialogue box will open to ask for system restore and then follow the above steps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I just had the same problem i was at my wits end , I took my tablet out to my garage and blew all the dirt out of it and to my surprise it works great now..... hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Reset the cmos battery on mobo, problem solved! If not then switch video cards or use onboard video!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jackie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 29
今までの合計 95,409
