メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Small metal ring dropped from logic board.
While following the guide to replace the earpiece speaker, step 19, removing the logic board, a tiny silver ring dropped from somewhere (see image). Have no idea where this goes. Put the phone back together without it. Phone is working well. Should I worry about this ring?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
This is the screw threads piece of the lowest screw on the so called WiFi Plate, plate that covers many connectors at top of iPhone. It is not a necessary part. It is held in place by the Y shaped metal piece and the screw. When you removed the screw it slipped out of place.
The location for this part is below the yellow circled screw:
http://d3nevzfk7ii3be.cloudfront.net/igi...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Oh how interesting! When I first went through the steps to tear down my iPhone and got to that screw, I wasn't able to unscrew it. It was turning but wouldn't come up, had to take a flat driver and push it under the screw head to remove it. When I put the screw back in, all I had to do was to "drop" it in its hole, no screwing needed. Now it makes sense.
Should I worry that this screw might come out of its hole by itself, or is the free space small enough that it will stay in place?
さんによる
コメントを追加
回答を追加する
Sccoaire さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 286
