メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
should new battery replacement for iPhone5 already have power
do i need to charge it first before turning on...or should new battery already have power
the whole story
ok i recently bought a water damaged iphone 5...first it would show apple logo for 3 seconds then disappear when plugged in...when i held home button for 15 seconds it would display connet to itunes screen ..once i unplugged it from wall charger it would go dead...it would not do anything once plugged to pc or laptop ...repair shop diagnosed and said bad battery and could fix for $90 ( yeah right ) i orderd new battery from amazon for $13 including tools and replaced it my self im kinda tech savvy :) ... only problem is i have no usb or wall charger as friend mistakenly took mines do i need to charge new battery first...or now do i need to replace dock connector also
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Explain a bit better of what is going on with your phone
さんによる
さんによる
コメントを追加
2件の回答
ベストアンサー
chris meadows, "only problem is i have no usb or wall charger as friend mistakenly took mines do i need to charge new battery first" eventually you will need to charge it somehow. So you may need to invest in a new charger/cable. Second you need to clean the logic board carefully. You said that it was water damaged, but did not tell us about any corrosion. I suggest that you disassemble your phone, using this guide. Get some isopropyl alcohol (90%) and clean the board and all the connectors with a soft toothbrush. Check for any burned, missing or otherwise damaged looking components. Take your time with that and use some sort of magnifier. You may have to clean the board a few times, depending on the corrosion, debris etc. After that reinstall and see what you get. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
try to damage the battery by yourself and go to apple store and get it replaced
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
not the most helpful advice..1)it's water damaged, apple aren't going to be to happy to replace, 2) this is a site for helping people to fix the device themselves. Perhaps some more constructive advice would be helpful?
さんによる
コメントを追加
回答を追加する
chris meadows さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 372
