メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Splendorとしても知られ、LG Optimus L7のバリエーションモデルです。通信キャリアにより、LG SnapshotやSwift L7(モデル番号:US730、LG730)と呼ばれることもあります。
How Do I install a LG730 LCD Display Screen?
I just replaced my screen on my LG730, now I am waiting for my new LCD screen to arrive. I am wondering, how do I install it? I have a rough idea, but never had to do it before. I spent time on the internet and could not find much. Does anyone have advice?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
Well I should have clarified. I Replaced the touch screen, which had a few spider web cracks in it. I also damaged the LCD screen, I do not know how to Take out, and put in the new LCD screen, at least with out damaging anything.
さんによる
Oh nevermind, I did a little tinkering around, and got it all situated, thanks for the help though man, I'll accent your answer.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Zack Borgen, I am a bit confused. You said that you replaced the screen, but now you are wondering how to install it. Did you check my answer from here:"
Take apart the battery cover using notch below
画像
Take apart the battery and remove screw (12 point)
画像
1. Unfastening the hook, make gap between Rear Cover and Front Cover
2. Widen the gap between Rear Cover and Front Cover and hook off starting from below side (back view)
画像
1. Take connectors & Side Key FPCB (1~9) out of the Main PCB
2. Widen the gap between Front cover and main PCB
画像
3. Remover the Bracket Camera to upper
画像
1. Unfastening the hook from below side, sh back side of LCD through a hole on back side of Front cover
2. Take apart Frame out of Front cover
画像
1. Lift LCD from the frame & Take off the LCD.
2. Be careful. Do not tear the LCD FPCB
画像
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I'll take another look at my LCD, but it does not just come off like the instructions show. So I'm sure I'm reading something wrong
さんによる
Thank you for accepting my answer. If you need to take a look at the manual, let me know. My email address is in my profile.
さんによる
コメントを追加
回答を追加する
Zack Borgen さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 16
今までの合計 1,860
