メインコンテンツにスキップ
iMac G4 17インチ 1.25 GHzモデル M9168LA 2003年発売のPowerMac 6,1です。
Unable to find drivers for this platform?
I'm getting this driver error, but I just bought it from someone that lives in my apartments so I don't have any idea what it could be. Here is a link to the pic if the error message if anyone can help me.
https://lh3.googleusercontent.com/-RFJYl...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Looks like a kernel panic to me. Possible causes: bad RAM, corrupted operating system, bad hard drive, or logicboard problem. The installed Operating System has all the native drivers the machine needs. There is no need to update the drivers.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Do you have access to the grey recovery disks the system came with? If not give Apple a call to order a set.
I do agree with Bernie you don't need any drivers. As it looks now you have a corrupted OS which could be as simple as re-installing the OS or the HD will need replacement. Until you can startup the system off a recovery disk or an external HD you won't know which.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
No I don't have the disks that came with it. I will see if I can come up with them. If it is the HD will I be able to put a Barracuda 7200.7 80GB S2ATA in it? I already have one, so I was hoping it would work in this one. Thank you both for your help!
さんによる
The G4 models had a Ultra ATA/100 HD interface not SATA so your SATA Barracuda won't work here, Sorry
さんによる
コメントを追加
回答を追加する
Kate Lowry さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 475
