メインコンテンツにスキップ
The HP Deskjet F4480 Printer/Copier/Scanner. This printer was intended for home or small office use.
everything printing out yellow
I bought new colored cartridge and worked great for one day and now everything printing out yellow
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
Try wiping the new cartridge bottom (where the ink spits out) with wet soft tissue. Maybe some of the jets are clogged up. If that doesn't work, get another color cartridge.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
If your HP Deskjet F4480 is printing everything in yellow1-855-731-7002, try these troubleshooting steps:
1. Check Ink Levels
  • Even if the cartridge appears full, low or clogged ink can cause issues.
  • Use HP’s printer utility software to check ink levels.
2. Clean the Printhead
  • Go to Printer Settings > Maintenance > Clean Printhead (or use HP’s software).
  • Run the cleaning cycle 2-3 times if necessary.
3. Check Cartridge Installation
  • Remove and reinstall the color cartridge securely.
  • Ensure the protective tape is removed.
4. Align the Printer
  • Run the alignment process from Printer Settings to improve color accuracy.
5. Use Genuine HP Cartridges
  • Non-HP ink can cause color imbalance. Try replacing with an original HP cartridge.
6. Print a Test Page
  • If other colors (cyan/magenta) are missing, the tri-color cartridge might be clogged or defective.
If the issue persists, the cartridge may need replacing, or the printer might require servicing.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Try steaming bottom of new cartridge over teapot , no gloves , if it's too hot you are too close, dry and replace.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
shelly さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 290
