メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
How to fix Time and Date Reset With no Battery?
I've come across a MacBook Pro 13" Early 2011 with no battery and for that reason it has the following symptoms:
1. Date and time reset every time the computer is turned off and turned on.
2. Every time I plug in my computer to a power source it automatically turns on
3. The machine resets to the year 2000.
I've investigated if this model has a PRAM battery but it seems it does not, it has a capacitor which needs battery power from the normal battery. Now my question is, is there any work around these issues without buying a new battery? Or do I HAVE to just buy a new battery in order to have this machine back to normal?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
I think you just need to buy a new battery.
Hope this helps,
John H. Laney
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Roberto Ministro さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,120
