メインコンテンツにスキップ
LGによって製造されたAndroidスマートフォン用の修理ガイド
2551回答 すべてを表示
My LG Nitro makes noises but no image after water damage.
I can hear my phone, making noises like my alarm and even the touch screen when I hit the keyboard I hear me typing my password but absolutely no picture whatsoever is appearing and this is after I dropped my phone two days ago in a pool on mistake can the phones still be fixed and if so how?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
There is a possibility that it can be fixed. More than likely there is corrosion on the LCD ribbon which is keeping the screen from displaying. Your going to need to clean the corrosion off before you know if the phone can be recovered or needs new parts.
You'll need:
-91% isopropyl alcohol
-Qitps
-soft bristle tooth brush( children's tooth brushes are best)
-(Optional) Compressed air, it will help with drying off components that need to be cleaned.
-And of course you'll need the tools to teardown down your phone.
Once you get your phone apart carefully look over your mother board and all the connections for your digitizer,LCD, volume ect...
If you see any corrosion take your qtip or tooth brush and clean as much as you can. Even if you dont see any corrosion on the connectors,just for good measure, clean all the connections anyway just to make sure.
When your satisfied with what you've cleaned, reassemble and check for any improvement.
Not a guarantee but its definitely worth a shot :)
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have same problem but my device is not battery removable :( what can I do!!
さんによる
Hi @ihuda ,
What is the make and model number of your phone? Also if it has gotten wet do NOT turn it on at all and also do NOT put it in rice either as that does nothing to help.
さんによる
コメントを追加
回答を追加する
mm5530 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 138
