The location of antennas in ipad4
where is the location of wifi and cellular antenna in ipad ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The wifi antenna is along the bottom frame toward the right. Sits between Digitizer and frame. The 4G antenna and GPS are at the top, also slightly adhered to the digitizer. If you look on the back, you'll notice black bars at the top of the ipad, that's where they are housed.
このアンサーは役に立ちましたか?
Is it the same as the ipad 3 3g version ?
Bottom antenna is for wifi/BT
There are 3 top antennas, 1 GPS and 2 cellular. iPad 3 and 4 should be very similar, if not identical.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,339
1件のコメント
i also want to know this !
could somebody help ?
Timmy さんによる
