need to replace the motherboard
I have mini computer ASUS with serial number is SN: 970AAS36893 and the PC 1005HA-PUIX-BK need to replace the motherboard is that ok
abdullah alshalabi, this guide is pretty close to the motherboard. Follow it and then remove the board. Or you can check this video, which shows you even more. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 229
Another way to replace the motherboard is you can download the service manual to replace it by yourself or you can also follow some online video tutorial for DIY.
david chase さんによる
