メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Phone screen shows a vertical blue streak after cleaned water damage?
I equipped my phone with a lifeproof case (I suspect that was my first mistake) :( and proceeded to use it in a pool. Inevitably water leaked in and it died. I put it into a bowl of rice until a couple of days later when I cleaned the logic board with a toothbrush and solvent, I successfully removed all corrosion... at least I believe I did. Yet, my phone will now only show signs of life when it is plugged into a charger, and still it only shows the time and percentage of battery life on the top of the screen. The rest of the screen is black except for a dark blue vertical streak. I think the battery is fine but I will soon install one that I know for a fact works, but still does it make sense that my phone would show signs of life with a battery problem? Any ideas on what would be the culprit of the elusive blue streak? Please Help!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
your lcd is bad... streaks are usually a sign of dead or or damaged pixels... and if it is only showing part of the display, the rest of the screen is damaged and cannot display and therefore that blue streak is just damaged pixels that are fortunate to still display color...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Wes, besides having a possibly damaged LCD, "only show signs of life when it is plugged into a charger" I strongly recommend that you replace the battery. Those batteries are smart batteries and do a whole lot more than just store energy. Replace the battery, double check your work about cleaning your phone. Use this guide to clean your phone. It was written for a 3G but everything still applies to your phone as well. Also, pay close attention to your dock connector, check for corrosion, bend or broken pins.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks! for the help, as for my phone, I recleaned it last night and replaced the battery this morning. Its getting better :) the screen now displays correctly save for some huge water marks. But the problem now is that it still won't hold a charge (I will inspect the connection for the connector), and it can't find a signal. Any further help would be really appreciated!
さんによる
コメントを追加
Do you know how to do it if the iphone 4s is dropped?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Wes さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 3,139
