maximum hard drive capacity I can install
Hi
I want to replace the 100Gb drive that came factory installed in my MacBook Pro 2GHz Intel Core Duo. What's the maximum hard drive capacity I can install? Thanks
この質問は役に立ちましたか?
Hi
この質問は役に立ちましたか?
Your machine can handle a hard drive with a maximum height of 9.5mm
640GB and 750GB drives are now within that range, you just need to confirm the height before purchase.
このアンサーは役に立ちましたか?
Agreed--these are suitable drives from ifixit. Ralph +
You need to format it using the "Disk Utility" application which is included with the OSX installer and format the drive as "HFS+ Journaled" It should then appear as a drive to install OSX on.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,277
