メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
iPhone 4s will not power on...
OK, so its been a while since i used my iphone 4s. its been in parts for about a year and I just recently bought all new hardware for it. The hardware I replaced goes as follows:
Proximity sensor
Home Button cable
Charger port
Battery
LCD Screen
I pretty much replaced everything in relation to power. I kept it on the charger for about atleast an hour. At most, the IC's under the camera warms up, but no other responses. The computer doesn't even read it, which is how i know it has not powered on. There was no water damage because i strictly took it apart to replace the exterior, but just got lazy. I also tried researching the schematics, perhaps I can try to find out where the flow of electricity stops, but its really hard to find. Looking for suggestions...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Right now i have no clue what to do...
さんによる
after researching, i think my battery connector might be faulty... i will check and continue to update...
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I truly think that your problem is the same as mine! In my opinion it's either the mother board that has a short circuit OR the grounding thingies that are supposed to be mounted a certain way and we're missing it...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
in desparation im gonna try placing the grounding cables and pray... i miss my iphone :(
さんによる
コメントを追加
回答を追加する
gtcoodyscoops さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,025
