メインコンテンツにスキップ
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
20回答 すべてを表示
Replacing motherboard in Asus Eee PC 1005HA
Hello, after few years my eee pc 1005HA is broke. I send it to IT shop for repair. they said some parts on motherboard has died. They said i need to replace the motherboard. After few search on the web, i found that the are 3 different laptop of this model. Question is. Does all motherboard of this type of laptops can fit ? I dont care about the differents in processors or bluetooth. I just need to know does they fit in the body of other models ? Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
p1nky, the difference is usually just the processor and other on-board architecture, while maintaining the same footprint. Always check with the vendor to make sure that you come as close to what you currently have. This will show you how to change the motherboard. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
p1nky さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 2,580
