メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
How to fix Error 2001, 2006 restore issues, possibly battery?
Hello. I bought an iPhone 4 online that said that it was stuck in error 21 and would not restore. After doing much research and trying different solutions, I am now getting error 2001 and error 2006 when attempting to restore to iOS 6.1.3 with iTunes.When attempting the restore, the "connect to iTunes screen" on the iPhone goes blank flashes quickly to a blue screen, and then to the apple logo, and then back to the connect to iTunes logo and either error 2001 or 2006 appears. (same thing when i tried a custom restore) I have the latest version of iTunes, am using a macbook pro mid 2012, am using an apple usb cord, and do not have any other things connected to my laptop. There is no battery icon that appears when the iphone is connected in iTunes, and the iPhone only is on when connected to the macbook. Will replacing the battery be the solution to having a working iPhone? (there is no warranty with apple) or have i bought a phone that cannot be repaired?
also the top water sensor indicates that there was water damage
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
ベストアンサー
KelsieHayes, "the top water sensor indicates that there was water damage" could become an issue. If you can, take your phone apart using this guide. then clean all of it with 90%+ isopropyl alcohol. Use a soft brush to clean the connectors and all the cables as well. Then replace the battery and check for any damage to the board. Reassemble and re-evaluate.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks so much! I am going to get the tools and a new battery. I will let you know how the repair goes.
さんによる
Sounds good, just take your time with it. It is tough when the description of the item purchased does not truthfully matches the item. Been there myself plenty of times:-) Thank you for accepting my answer.
さんによる
コメントを追加
回答を追加する
KelsieHayes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 28,945
