メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Sleep/Power button doesn't work
Hello!
I have a iPhone 5 the device never drop.
But today the right side of sleep/power button stopped working (only on right side,the left side of the sleep/power button work)
How I fix it?
Try Contact Cleaner Spray?
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
I can also confirm that this is a common issue and will be covered under your apple warranty.
I have had two iPhone 5's replaced by apple for this very reason, they must have used a weak part as a lot of people are having the same issue.
Go to the following page and start your apple service requesthttp://www.apple.com/support/iphone/cont...
The following is where you need to click.
"Apple Support" then "Get Started"
"Service requests or troubleshooting" then "Buttons not working" then select "Sleep/Wake Button"
Within 2 days a package is sent and once you have sent it off a new iPhone will be on its way back to you within 5 days, thats right a new iPhone 5 for a button issue. Must be costing them a lot of money.
Anyway let me know how you get on.
Cheers
Brendan Mills
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I do not live in the USA.
I can not send the device to Apple Store.
If I use spray cleaner contacts that can help?
さんによる
I don't live in the USA either, Apple will give you an option of how they can get it replaced. They must do in order to fulfil their legal requirements for the warranty.
I would never touch anything under warranty, but if you really want to then, it not a question of cleaning the button, the actual push switch will be faulty and will need to be replaced. This is the guide you will need to complete in order to replace the power button, iPhone 5の音量コントロールとパワーボタンケーブルの交換
さんによる
コメントを追加
最も参考になった回答
I've seen this on several iPhone 5's so far. Usually the button still "clicks" fine, but just doesnt function correctly. If its still under warranty, you can take it to an Apple store and they will replace. Its a part issue. If its not under warranty for some reason (they come with 1 year)....Then you need to replace the power/vol/mute flex cable. This is about a $8 part online just about anywhere. Its rather difficult to replace.... it takes time and patience to install correctly. But it will resolve the issue as well.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Avior さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 36,816
