メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Why is my screen black after I fixed the cracked screen?
So i drooped my iPhone and order a new screen and followed step by step instructions . When it came to the end i tried turning it on and all i get is a black screen. but i hear it open when i press the lock button , but its just a black screen . Can anyone help ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
Anna,
there can be couple different problems:
1) LCD you installed was defective (or damaged during installation, trust me that's common for DIY)
2) LCD is not plugged in correctly to the board ( you can try to open it and re-attach the LCD connector to the board and restart the phone holding home+power button)
You can also check, if you still have the old LCD assembly, you can connect it from outside bu just disconnecting cables for LCD installed on the phone at this time and bend them back so you can give enough space for different LCD to be connected just plug it until you hear/feel the click and try to power on the phone. In case this will work you might need to replace the LCD screen assembly .
3) LCD connector on the board is broken (see if this was not damaged during installation)
4) Yay! any water damage???
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I agree you probably damaged the screen. This would be the best possible scenario since its a part you can replace, again!
I would have someone else do it this way it's all on them.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
anna さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,290
