メインコンテンツにスキップ
The fourth Google Nexus smartphone, released November 13, 2012.
75回答 すべてを表示
What do I need to fix a cracked nexus 4 screen?
Hello,
i also dropped my nexus 4, it was a little drop but the screen has one scratch (not a big one) but the touch working in some places in the screen and not working in other places.
can anyone advise me which part should i change?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
You should change the whole screen assembly and you can learn how to replace it from this video http://www.youtube.com/watch?v=AZDAIgwbX...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hello!
The part that needs replacing is the display assembly.
You should be able to find one fairly cheaply but remember that you usually get what you pay for, so don't go for the lowest priced one, go for one in between. The ifixit shop does not stock the required part so try eBay :)
If you're not confident replacing it yourself then take it to a mobile phone repair shop if you are then proceed and reply with the results!
ifixit does not currently have a guide to do the repair, there may be one else where but I just thought I'd give you the heads up :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Where do I take nexus 4 cracked phone to fix it in Briarwood Mall Ann Arbor Michigan
さんによる
コメントを追加
回答を追加する
ariana さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 6
今までの合計 13,950
