メインコンテンツにスキップ
Released around 2010, the Dell Inspiron 15R N5010 is a 15-inch laptop with an Intel processor and dedicated ATI Radeon graphics card.
How to get WIFI and Bluetooth drivers for dell N5010?
I need the wifi and bluetooth drivers of the dells as i can't get them in any site ....plz any one can help me for finding this.....
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 12
1件のコメント
just visit dell site to download the driver visit https://goo.gl/SSBGrW
さんによる
コメントを追加
3件の回答
ベストアンサー
First you have to know which wifi card is installed on your device but i link you all possible drivers.
Go to this site and click in the menu Drivers&Downloads there you can find all drivers.
http://www.dell.com/support/troubleshoot...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Apparently seems like your W-LAN card is either disabled from your network connections or may be there is some hard switch which turned off. All you need to go open network and sharing center then click view network connection to make sure that you Wireless connection is not disabled in any case it should have to be enabled.
Other way is to check on your keyboard from top F1 to F12 keys if you can see a Antenna sign on any of key then press that key by pressing Fn key together.
If the problem still persist then I would recommend you to go on your manufacturer`s website to download the latest driver and update your driver. Good Luck
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Thank you very much/ my laptop is i5 Aspiron N5010-window 7 64 bets
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Raviteja Adusumalli さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 45
今までの合計 20,956
