What type of engine oil can be used
I am use Toyota camry 1997 model. I want to know the grade of engine oil to do services, when it is due for service.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
isafiadeo, change your engine oil regularly, using an API certified, grade SJ or better engine oil. 5W30 is the preferred viscosity, but you may use 10W30. Use this guide to change it. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 15
過去 30 日: 53
今までの合計 103,725
