outlet trips after a while causing Refridgerator to turn off?
Hello
When I plug in my kENMORE 25361662101 it turns on and appears to be working, but then after some while it trips the outlet and turns off. I tested the outlet and its good and only have this issue when the refrigerator is plugged not with any other appliance! I realized there is no sound coming out it when plugged or turned on, (like a fan or motor? the outlet trips and doesn't stay on long enough to freeze or keep items cold. appreciate any suggestions. thank you all.
Mike H
この質問は役に立ちましたか?
5 件のコメント
What sort of breaker is being tripped over current or earth leakage? Is the Fridge the only appliance on that circuit?
Richdave さんによる
Mike H, sounds like your fridge could be drawing to many amps which will trip the breaker. How many amps on that circuit breaker?
oldturkey03 さんによる
see if you can post some images of the wiring as well as the components that you see. It is possible that you have a bad compressor run capacitor
oldturkey03 さんによる
Hello
thank you all for the questions, I m plugging in a ground-fault circuit interrupter (GFCI, it is the only appliance.
Mike H さんによる
Sounds like the amp off that circuit should be okay. Take a look at the compressor and the rest of the wiring. See if there is something obvious (I still go with a bad cap first;-)
oldturkey03 さんによる
