メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
White Lines on iPod Touch 4th Gen LCD
I have replaced the LCD/Digitizer on this iPod, and when I plug the power in (or turn it on), if I leave the screen kind of there, but not pushed down all the way, it seems to work great. Picture is good, touch works, etc.
However, when I go to press the screen down (i'm test fitting before removing the cover from the adhesive), I start to get horizontal white lines. Once I see them, I stop immediately, because I don't want to damage anything.
What could be the problem? Could it be that I don't have the LCD cable plugged back in correctly/all the way? Is the LCD cable the one that plugs from the top of the logic board, or the one on the botttom?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Sounds like you have bought a bad LCD . The LCD is the one that plug in on top of the logic board
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for the response. It turned out to be that I did not have the LCD plug seated correctly. Once I got that seated correctly, it worked.
さんによる
コメントを追加
My iPod has horizontal lines on it and I can't see my screen properly
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bobby さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 891
