メインコンテンツにスキップ
Repair and disassembly guides for Sony DVD players.
65回答 すべてを表示
DVD player is not reading DVDs or CDs
Sony DAV-DZ690K
I own this four years old Sony Home Theatre system. I noticed recently, it is not reading either DVDs or CDs. When I insert a DVD, it takes a while to read, but shows 'No disc'. The tray simply opens on its own.
I appreciate your help to solve this problem.
Thank you so much in advance.
Narni
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
Mine takes awhile loading then says can not play this disc.
さんによる
I wanted to know the spray that is used in cleaning of the lens inside the DVD
さんによる
コメントを追加
3件の回答
最も参考になった回答
Narni, sounds like either a dirty laser or a burned out laser. Try one of the commercially available lens cleaners. If that does not work you may have to disassemble your player and clean/replace the lens assembly. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs.
Any advise is welcome!
さんによる
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs. Any advise is welcome!
さんによる
コメントを追加
Try another disc or try another drive to make sure which causes the problem. In most cases, it’s a scratched DVD or a dirty drive. This post has shown all the possible reasons and fixes.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Push power protector
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Push
Reasonpower protector not working
さんによる
コメントを追加
回答を追加する
Narni さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 13,624
