メインコンテンツにスキップ
モデル番号 A1051 / 4 もしくは6 GB ハードドライブ
87回答 すべてを表示
iPod mini making clicking sound, won't boot up?
My iPod Mini comes on and shows an Apple symbol. After about 10 seconds or so, it gives the Apple web site address. Also, it displays a symbol of the drive with a line through it.
The iPod Mini is charged and battery is OK. When turned on it also makes a clicking sound similar to when a hard drive is failing.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
選択されたソリューション
Just get a Compact flash card and call it a day. You can't buy new MicroDrives, and a CF card would make this more stable and load faster in baby situations. Any reasonably large card (8GB+) will usually work, although you may need to do some research to be sure first.
Once the card is installed, you will need to restore the iPod in Disk Mode. To do this, hold the center button and the play/pause together until it's in Disk Mode. Restore it in iTunes when this is done.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Thats your problem. The MicroDrive has failed. If you can get hold of one yourself, you could swap them out. If not, a repair company, such as www.dr-pod.com could repair it for you.
Mark
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Charles Scaglione さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 4,151
