no signal
please i have wifi in my phone and no signal sim i change blue coil
この質問は役に立ちましたか?
Go into ( Settings - General - Date & Time ) you will see "Set Automatically" If it is set to "ON" flick it to "OFF" wait a few moments then flick it back to "ON". In the case you do not see results within a few moments give it a minute or two to reconnect to the network and update your settings. Make sure your sim card is inserted while you do this.
このアンサーは役に立ちましたか?
Sometimes that will occur if your date and time are not set correctly. Occasionally when the battery is disconnected, the phone will stop automatically updating the date/time correctly. If they are incorrect, correct them and restart your phone. Good luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 1,026
1件のコメント
Is this cable connected?
Chandler Skinner さんによる
