メインコンテンツにスキップ
The sedan version of the compact Toyota known as the Echo, Yaris, or Platz depending on the market. The hatchback version of the Echo/Yaris is known as the Toyota Vitz.
11回答 すべてを表示
if battery no longer holds a charge
can u still jumpstart it from another running vehicle?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
選択されたソリューション
If you want to jump start the car it will run as long as the alternator is working well . If after you start the car and disconnect the boosting battery the car dies then the alternator is not working correctly. As for your question Yes you can but remember every time it stalls you will need to boost it again . Hope this helps
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Hi Jim,
Given the posting date of the question, I don't think that they will be still interested. As for other people reading your reply it is good advice.
さんによる
Hi John I noticed the date and was flagging the spam answer at the bottom when I thought hey why not someone else may want to know
さんによる
コメントを追加
yeas but as soon as you remove the cables it will stall because it takes the juice from the other (good) battery
but i would get a new battery
-i have a blem in my car and i have no problems with it
- i even ran the battery for 2.5 hours with nothing but the radio on and it started no problem
by the way a blem is a new battery with no label on it
the one i have is from interstate which produces great batteries
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It will not stall "as soon as you remove the cables " since it will receive power from the alternator once the engine is running.
さんによる
コメントを追加
回答を追加する
shelley さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 1,207
