My screen in dark
My laptop is starting up but i can see the screen but not enough to see the setting to try and fix it has any one any idea on how to reset them to fractory setting from startup
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Plug it in to an external monitor to both test the graphics chip and see if you have display problems.
このアンサーは役に立ちましたか?
The video on the external monitor should allow you to make changes if the problem is software. + Ralph
You want to try resetting the PRAM. Hold command, option p and r while booting the system. You want to wait till it restarts twice. So the third time you hear the initial chime let go and let it boot up. As long it is just the video setting and not the backlight being out this should help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 1,165
