メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
black screen after screen replacement
After replacing the LCD/digitizer on an iPod 4th Gen it will not turn on. I have tried holding down the home button and power button, no luck. I have left it for 24 hours and then plugged into a wall charger, still no luck. I have tried shorting the positive battery terminal to drain the battery, no luck. Double checked all the cables, ribbons, tried a different screen, even tried the broken screen that was working when I took it apart. All with the same result, black screen, computer does not see it and there are no sounds.
I have successfully repaired many iPod 4th Gen but the last 3 in a row have given me this same problem.
Any suggestions and help would be greatly appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
最も参考になった回答
i would try and short the battery again its the 1 to the far right short it of the metal frame around the home button. hold it there for atleast 5 seconds
Update
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
same problem but ipod touch 5th gen screen replaced but black screen itunes recognises the device so it is operational but screen is still black have try tried holding power and home key but nothing happens does shorting out work on this model?
さんによる
コメントを追加
Did you find the answer? I have almost the same problem as you... It's so annoying! -.-
Update
The same here...i have fixed many ipods before. Still can't figure out what the problem is. Just a screen replacement, but turned out to be a bigger problem this time. Well, i'm not giving up till i have fixed this.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
No. I have tried shorting the battery. Even removed the battery and reconnected it. I still have the same problem. I must have shorted the main board somehow.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sullivansolutionz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,007
