メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
IBMは現代PCの先駆者的メーカーで、IBMより製造されたラップトップモデルの修理ガイドです。
How to replace LCD rear cover
IBM ThinkPad X40:
I've read the X40 HMM(hardware maintenance manual) very carefully, and still not confident to replace the LCD rear cover.
Last week following the HMM, I replaced the hard drive with SSD(indeed with msata SSD + 1.8" msata IDE adapter). There were many steps(remove keyboard,palm rest, upper case, then can only touch the HD slot, and it was very easy to break some tiny plastic tips on the palm rest.
With the HMM, I know I have to do all the steps again to replace parts on the LCD Assembly(particular the LCD rear cover).
Any instructions available I can follow to skip over these steps and replace the LCD rear cover directly?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Mike Yue, the reason why you can notstep any of these steps is precisely this "There were many steps(remove keyboard,palm rest, upper case, then can only touch the HD slot, and it was very easy to break some tiny plastic tips on the palm rest." If you want to replace the cover properly, there are no shortcuts that you can take. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mike Yue さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 180
