Our company buys back broken LCDs assemblies and phones from repair shops. We've been through thousands of iPhones with this issue.
My gut feeling is you have about a 75% chance that it's a bad LCD digitizer assembly and a 25% chance that the connector on the board is bad or other board related problem.
Humm... actually thinking, you wouldn't want to try the screen first. You say it wont power on. First thing is to make sure the battery connector is still connected to the board. You can see this fairly easily by removing the back cover (but be careful and read how to do so first)
For "free" you should check that and maybe it will cut on and just have a cracked screen.
Does the phone make any sound or show any signs of life? Anything show up when you plug the charger into the phone?
...if no signs of life (sound, vibrate etc, assuming that the phone has enough battery to juice up) ...you probably have an issue non related to the broken LCD screen but could have both.
If you have it charged or can charge and can feel vibrate when you hit the switch or head sounds or calls with no display, then it's the LCD.
4 件のコメント
Cody, what did it end up being? I've done the same except only broken the back. I've ordered a repair kit to replace the back panel. I'm hoping the battery connection is jarred loose. Were you able to resuscitate your phone?
righthip2 さんによる
I don't know how to fix my phone I've tried everything but nothing seems to work. I think I have a very unique problem. My phone is cracked and when I turn it on, light shows through the cracks and a weird glitch looking thing shows on the top right corner of the screen. I can still hear the buzzing from if I get a text or if I turn the ringer off or on. I've tried everything, but nothing seems to work, or is not the problem that I have. I don't know what to do and I don't want to spend a lot of money on get it repaired. What do I do?????
Cojo さんによる
I have those same problem like amy my phone is plugged in but it only vibrated once and I have a iPhone 7
Tamia Martin さんによる
@tamiamartin You'll have better luck getting an answer if you post this as a new question under the proper iPhone 7 device category. Go to the main page of the Answers Forum and click on the blue Ask a Question button at the top right of the screen.
Jerry Wheeler さんによる
