メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
My Lumia 920 died. Why is it not charging or starting up?
The phone turned off while my son was playing a game on my Lumia 920. I tried to charge it, but it did not charge—and it's not even showing Nokia Logo. It shows nothing—just like a dead phone. I tried both hard and soft resets, but nothing works.
I thought it was the charging port because there was a small physical defect near the USB charging port (voiding the warranty). I ordered an OEM USB port charging connector flex cable. I changed the charging port.
Now I see that it installed the driver on my PC when I connected through the USB cable. But it's still not charging, and it displays nothing when I try to charge it or power it on.
What can cause this problem, and which part needs to be changed in order to work properly? Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 17
22 件のコメント
Hello,
When you had it apart did you look to see if any of the connections where still connected? Maybe a connector to the screen has been loosened? Or perhaps the screen itself has gone bad. I would suggest to check all the connections inside the device.
さんによる
Thanks @JSmith, I tried to look for cables that can be loose. I only see Battery cable and microUSB Charger Flex Cable. I tightened both of them. Do I need to disassemble the phone further to look for more cables? Can the screen go bad by it self?
Thanks
さんによる
Have you checked your battery with a multimeter? Have you replaced the battery yet at all? You said "physical defect near by USB charging port " where is near by? Post an image of the "area" with the defect with your question.
さんによる
This is an image that shows the defected area http://i.imgur.com/zZf2nfq.jpg
さんによる
if you will try charging by usb to computer it will charge somehow it is a fault with phone because alot of people have this problem with the lumia 920
さんによる
17件以上のコメントを表示
コメントを追加
13件の回答
ベストアンサー
I had this situation before with my Lumia 920. Just press the volume down and power buttons for a few seconds to perform a soft reset. After the phone has started again, you have to set the date and time.
このアンサーは役に立ちましたか?
スコア 27
45 件のコメント:
I tried hard and soft reset. Its more than that.
さんによる
wow Sven Wilhelm , i have the same problem and it works when i press Volume down and power button at the same time for a few seconds. Thanx a lot, i almost packing it and send to Nokia for repair. :-)
さんによる
Thanks Sven Wilhelm. I reset my phone now its working.
さんによる
Volume down and power button for a few seconds to perform a soft reset worked for me.
www.sarthakpatel.in
さんによる
さんによる
40件以上のコメントを表示
コメントを追加
Try the reset first. Press and hold the vol down+power+camera buttons. Release the power button when the phone vibrates and release the remaining 2 buttons about 5 seconds after that.
100%working Abdelrhman Abdalla
このアンサーは役に立ちましたか?
スコア 5
5 件のコメント:
100% solution
Pls do it like this:
* Press and hold the
* when the phone vibrates
* about 5 seconds after that
さんによる
I tried this but didn't work for me
さんによる
No sign of working at all
さんによる
Not working at all. Is there anything else I can do?
さんによる
This is working perfectly, I already had decided to throw my L.Nokia and never buy the same kind in my life. Thanks Guys.
さんによる
コメントを追加
a do soft reset ( vol- and power) bat not working! open device and disconnect battery flet and wait 10-15 sec then connect back and put back mask, and connect charger. this worked for me. ( sorry for bad english) :)
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
http://jkorondy.com/Lumia920 to download firmware updater (Nokia Software Updater 4.1.0)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When you remove the battery and connect to the charger does it start up or no? If no, you most likely need to replace the charging port. You can check your charge port with a multimeter. I highly doubt it's the display, because even if the display is dead then there would still be SOME sign that the phone is on. (An indicator light, vibration, noise, etc.)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
as ive been trying to say the whole issue with my lumia 640 not xl after two days I left it in a window as it got to hot when I came back it said on the display overheated and needs to power off but it did not power off as it detected instead it stayed on until user input, after this it was all over for the battery, I then took another battery from same type of phone and all was well again as if it never happened, as ive said there is a sensor overheating detection device on most batteries today for smart phones. once they are triggered it seems inpossible to fix without buying new, as youtube will show how to bypass this sensor it will not work with lumia 640's the battery is sealed in a way that will destroy it trying to solve it, also the charge port is normal with that high raised center on the port its normal and Is for a tighter fitting charge wire,..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just had the same problem. Solved it by taking toothpick and cleaned up thoroughly the USB/charger port.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Nokia smartphones don't seem to want to charge when the battery is in a low charge state. Most people these days are using a USB charging lead via a laptop or the standard plug in the wall charger with USB take off. The original charger looks the same but it is a 2.0 amp output laptops are only 1.0 amp and most other phones charges are also. It means when you plug your lead in the phone switches on and the battery is in a low charge state the phone is using more power than the charger is supplying. Answer use original charger or any 2 amp charger till the charge gets past 20% then you can go back to a 1 amp. That Apple i phone as a 2.1 amp charger so if your mate or girl/boyfriend as one you can use theirs to get you to 20% then leave them. Or there is a car plugin charger on the market that as 2 USB outputs one is 1 amp and one is 2.1 for that other companies phone. Or you can buy on ebay a 2 amp wall charger with dual outputs for about a fiver. For that time when you forget to charge the phone. It works no reset soft or hard just 2.0 amps needed.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
PS it is the same for most newer smartphones
さんによる
コメントを追加
i am tired this option not work for me i have lumia 720 and i am trying many time for volume down + Power button but its not working my phone now showing black screen link dead mobile please help me what I do know?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
There was some experience with snow 920, it is impossible to run an attempt to fire, but it does not succeed, only the NOKIA logo appears but it does not work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
on its own my Windows 640 XL wont switch on. only when i have connected the phone to my laptop does it come alive.have also tried to use a different laptop but with no solution.there is an app on my laptop called Windows phone app for desktop .i suspect it enabling the start up. need a solution for the phone to be self starting.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a Lumia 640. After an extensive tour in South India, where I captured many excellent pictures and videos on this camera, I tried to charge my phone in a taxi. The phone went dead. There is no display and it does not work. It just vibrates once, when I press the power button. I used a different battery from another Nokia. Still the result is same.
I took it to the repair shop in Hyderabad. They told that it is a hardware issue and that they cannot retrieve the data.
Can anyone suggest a way to retrieve the data or suggest a Nokia repair shop where they can repair the hardware and takeout the data? Or is there any simpler solution?
Request your help.
thanks.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have tried hard reset but still not charging and no volume it only vibrates
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mohamed Ali さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 15
過去 30 日: 74
今までの合計 159,732
