keyboard problem letter failure
the books keyboard letters 8 As well as I plus the leter K and , dont respond. looks like they fail in a straight line across the keyboard.
any suggestion how to solve this problem?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you have access to a damaged keyboard you could try to stick the little nipple back under those keys (sounds like they were torn off) failing that I would replace the entire keyboard.
Remember to return and mark accepted the answer that best solves your problem.
このアンサーは役に立ちましたか?
thanks machead, no its not the nipples, it has to do with the solderingfield i guess, all the lettters are in a straight line down from top to bottom of the keyboard.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 150
